Kingpin Replacement?
I took my 1973 F100 in for an alignment and the guy told me that he can't align it because the pins are loose. I checked them and he was right. Ok, so I need to replace the pins. I want to use the bronze bushings instead of the mickey-mouse delrin bushings. Where can I find a 7/8" ream long enough for reaming out the new bronze bushings?
Thanks,
Ron
Thanks,
Ron
reaming king bushings the right way
The best way is to ream the bushings is with the proper king pin reamer. It will have a long pilot shaft that slides into a sleeve that has a tapered out side. The taper sleeve will center the pilot in the opposite bushing to guide thr reamer thru. Turn the reamer around and go the opposite way on the other bushing. When done the two bushings are inline. I had two sets of bushings wrecked by having them done by hone. I was lucky as i found a king pin reamer in the right size at a machine tool garage sale, it was new in box at $35. If my thinking is correct the size was .860". Carl....o&o>........
Before you do anything make sure the anchor bolt is tight,I have had many truck in my shop for pin replacement only to find the pin moving in the axle itself and not the bushings,also see a lot of "techs" not no the difference between kingpins and thrust bearings.For the record, I ream 90 % of the time, the other 10 % go to machine shop mainly due to time problems,they hone.
jimcar-9
03-14-2014 01:42 PM
JEDWIN
06-10-2005 07:17 AM
