Door lock diagram
Old 10-18-2004, 11:02 AM
flairside-ut5's Avatar
flairside-ut5
flairside-ut5 is offline
Door lock diagram
For a 1995 Ford F150 - does anyone have a diagram of the connection between the door lock cylinder and the lock? The power lock still works, but the key lock is disconnected. There is a curved rod connected to the lock, but it is just dangling loose on the other end, and I suspect there is some kind of connector to attach to the lock cylinder.
Thanks for any help.
Old 10-18-2004, 02:39 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
did you look in the crap at the bottom of the door? that is where the clip probably is.
or, take off other door panel to identify part.
or, go to advance or napa or any auto parts store and see if they have one.
or, got o ford and just get the diagram and part and be done with it.
good luck.
janschutz
12-08-2018 08:40 AM
Calgary Ole
1997-2006 Expedition & Navigator
12-31-2014 12:11 AM
7622RM
1983 - 2012 Ranger & B-Series
10-23-2013 08:33 PM
TJ Johnson
07-22-2013 06:25 PM
walt460
21
01-01-2009 09:03 PM
Quick Reply: Door lock diagram
