99 Navigator door lock cylinder
My driver door lock cylinder fell out a while back. I have the cylinder and some other bits that I was able to find in the door and would like to re-install. I can't find a good diagram of how it all goes back together. I will need to find or fabricate a couple clips etc to restore so a diagram or part#'s would be appreciated!
TIA
TIA
Really? Hmm, that's interesting, I always thought there was one on both sides on my 01 Navigator, I actually had to go out and found it's just like yours. I know my 97 expedition had locks on both sides, I guess Ford got cheap and figured they could save a few bucks.
The key would only be used when the key fob is lost or batteries need replacing.
If so, why put a cylinder on both sides?
Alloro, you proved that point, not knowing or ever using that passenger side cylinder.
Since we only have one key fob for her car, I carry only a key. The problem... I like to open the door for my wife when we get in and I can't do it when I have to open the car, only from the drivers side. Just not that fast to get over to the other side!
On a side note, I. Went out and tried the rear door cylinder with the key and it did not fit. Was there a second key that I have misplaced and forgotten of a different size/pattern?
Going back to my Expedition again. When I first got it the ignition key would not work in any of the doors or in the rear hatch. I had to remove each cylinder and soak them in oil and work the key in and out, back and forth for a long time. They were corroded and frozen up because the PO always used the FOB to unlock the truck and never the key.
026TB4U
1997-2006 Expedition & Navigator
12-19-2010 02:17 PM
ntmmd8r
07-31-2006 07:14 PM
