Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-17-2004, 07:54 PM
richard jobe richard jobe is offline
Garage is empty, add now
richard jobe is starting off with a positive reputation.
t 5
i asked about t5 transmission on other forum got some responce and
places to get adapters 300.00 i am looking like everyone else cheep date
ha ha go fast for cheep richard jobe flathead 55 mph i put bigger tires
gained 5 mph still risk life & limb on houston freeways better now with 8 volt lights when it was 6 volt look out they pass on the left & right
richard jobe channelview tx
__________________
richard jobe
  #2 (permalink)
Old 10-30-2004, 09:33 PM
dick1950 dick1950 is offline
dick1950 is starting off with a positive reputation.
t5
You can make your own adapter. I brought a piece of one inch thick aluminum to my machinist with my bell housing and T5 and he made an adapter. worked fine.
Dick
  #3 (permalink)
Old 10-30-2004, 09:37 PM
adapter
thanks i will keep in mind i have been looking for different ways thanks
richard jobe
__________________
richard jobe
  #4 (permalink)
Old 11-03-2004, 09:06 AM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
I like the adapter fabrication idea. Is there any documentation available for the design? How did you know how thick to make it. Do you have a photo. I love the idea of a T5. My F3 with 4.86 final drive ratio could use one.
__________________
SteV8e
1952 F3
Put this in your signature if you are a Christian with an Effie!
  #5 (permalink)
Old 11-03-2004, 10:39 AM
Adapter
I installed a T5 in my 1950 Ford Convertible and will be doing the same in my 50F1. Although no documentation per se, I can help you somewhat.
I bought a 1 inch thick aluminum plate 12"X12"X1". I took the plate to my machinist with my bell housing and T5. I had holes drilled for recessed cap screws holding adapter to bellhousing and he also machined the hole opening for the input shaft as well as locating the T5 and drilling the holes in plate to attach the T5.
Yes I have pictures but am not sure how to insert them as I am a new member
Dick
  #6 (permalink)
Old 11-03-2004, 11:14 AM
SteV8e's Avatar
Dick:
I would love to see your pictures. The sequence is like this:
1) At the page top, click on "Galleries".
2) Click on "Manage Your Gallery"
3) "Create Album"
4) Fill in the blanks and follow the instructions.
Send a reply when you get your pictures in an album.
__________________
SteV8e
1952 F3
  #7 (permalink)
Old 11-03-2004, 03:00 PM
OK, I d made a gallery. You can see the t-5 adaptor, a mock up on a spare block and a few pictures of my F1 project.
Dick
  #8 (permalink)
Old 11-03-2004, 03:32 PM
SteV8e's Avatar
Dick:
Very cool. Thanks. Is the T5 from an S10? How much should I expect to pay for one? Anyway to evaluate the condition?
Thanks
__________________
SteV8e
1952 F3
  #9 (permalink)
Old 11-07-2004, 05:43 PM
adapter
great pic of adapter is the shaft long enough? great set i have 5f1 also
thanks richard jobe
__________________
richard jobe
  #10 (permalink)
Old 11-07-2004, 07:32 PM
T5 Adapter
The T-5 was form a 88 S-10 and was 125.00. It had 65,000 miles on it and had evidence of recent repairs (blue goop). I put it in and it worked.
The longer output shaft on the T-5 and the 1" Adapter plate equaled the length of the output shaft of the cars overdrive. I had about 3/8 of an inch available to cut off the very end new output shaft, if necessary. But it was not necessary.
Dick Listro
  #11 (permalink)
Old 11-07-2004, 08:01 PM
reply
dick thanks for the reply i wasnt trying to be dumb somtimes people get excited & leave out stuff like than thanks richard jobe
__________________
richard jobe
  #12 (permalink)
Old 11-08-2004, 07:12 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
Richard
Please make a note that the wonderful job Dick did was on a CAR Bellhouseing, the Bellhousing standard to these trucks was much shorter.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #13 (permalink)
Old 11-08-2004, 07:50 AM
SteV8e's Avatar
How much thicker would an adapter need to be for a truck bellhousing? Or, should a car bellhousing be used instead?
__________________
SteV8e
1952 F3
  #14 (permalink)
Old 11-08-2004, 11:53 AM
4tl8ford's Avatar
The diference is significant.
You would end up building a pyramid looking device that would be a bear to align.
I would look for someone to swap bellhousings with.
A lot of people look for the truck bellhousings when they want to put a late Flatmotor in an older vehicle and keep the original tranny.
I'm looking for a car bellhousing now so that I can mount a Ford Top Loader in my Panel.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1997 Ford Explorer
  #15 (permalink)
Old 11-11-2004, 10:57 PM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
Does the 51 6-cylinder flathead use the same bellhousing. I would like to replace that non-syncro 4 speed.
Tags
1950, 352, 4953, 53, adapter, fitting, flathead, ford, input, length, plate, s10, shaft, stick, t5, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
