Over Head Console 4x4 switch
my bronco II i just picked up 2 months ago was fine until today.my 4x4 over head console indicator
is not working at all no lights no 4wd no nothin
and i can't even find the fuse for this system.
if any one out there can help me I would appreicate it
thanks harry c
thanks harry c
Harry, First if you haven't been using 4wd often,you will need to remove the electric motor from the rear of the transfer case and take it apart. Clean the armiture and brushes, reassemble and then try it. Most likely will solve problem. This happens all the time, because motor has to be engaged at least 1 or 2 times a month. Let me know how you come out
James Patrick Harris
06-06-2013 05:18 AM
27
01-11-2013 03:05 PM
