2002 Explorer Pinging
Old 06-04-2004, 06:34 PM
biit55's Avatar
biit55
biit55 is offline
2002 Explorer with 4.0L engine and 27,000 miles pings. Taken to Ford 3 times and they ran it through a bunch of "test" and found nothing. They called Ford Hotline and were told its normal?? They did de-carbonize but that did not help so the idiots set the timing back 6 degrees - the max Ford allows. It still pings.
I took the advise from this forum and replaced the intake manifold gaskets, decarbonized the engine again myself, checked EGR operation, checked for and found no vac leaks (Ford also indicated that there were no vac leaks) still have the same pinging.
Pulled the MAF twice and cleaned.
After performing each thing above the computer was reset (disconnect battery for 15 minutes). Still have pinging. Any other ideas??? Thanks.
Old 06-05-2004, 12:20 PM
4x4Ford's Avatar
4x4Ford
4x4Ford is offline
Old 06-06-2004, 09:18 AM
biit55's Avatar
biit55
biit55 is offline
4x4 - Thanks for the info.
Old 10-09-2004, 10:36 AM
muleman's Avatar
muleman
muleman is offline
did you ever fix this? I have the same problem, i changed wires it stoped for a week. Then changed plugs, same stop for a week, still pings under light throttle. I also tryed running 93 octane. Nothing will stop it but a BIG TREE.
Old 10-09-2004, 05:08 PM
chazglenn3's Avatar
chazglenn3
chazglenn3 is offline
Are you sure it is pinging? The 4.0 SOHC is known to have timing chain rattle problems. The 2002 Explorer that my wife drives is plagued with this problem. The rattle is only heard from about 2400 RPM to about 4000 RPM and sounds EXACTLY like the engine is pinging. There is a Technical Service Bulletin out for the fix, and since you are still under warranty, I would take it in and have the TSB performed. I am living with the noise for now as I am out of warranty. I hope this helps.
Charles
Old 10-09-2004, 05:33 PM
muleman's Avatar
muleman
muleman is offline
i have 110k on it ready to trade it in
Old 10-09-2004, 06:54 PM
chazglenn3's Avatar
chazglenn3
Sorry, I was thinking about the original poster...I didn't realize how old this thread was. We are coming up on 100k on our Explorer, and outside of the whining rear end and the timing chain rattle, it's not a bad truck. Yours is a pinging for sure, then?
Old 10-09-2004, 07:41 PM
jhromy's Avatar
jhromy
jhromy is offline
and what does a ping sound like and what about the timing chain rattle...what does it sound like???
4x4pwr
Modular V10 (6.8l)
06-07-2015 10:12 AM
ham-n-swiss
06-03-2009 03:59 PM
opeterson
03-26-2006 05:20 PM
citus
10-03-2002 11:21 AM
jopey
19
08-26-2001 01:22 AM
Quick Reply: 2002 Explorer Pinging
