2v 4v intakes.. whats the differance?
Old 10-04-2004, 08:49 PM
Scopie's Avatar
Scopie
Scopie is offline
Question 2v 4v intakes.. whats the differance?
Gday guys. I'm about to take a trip to the wreckers to pick up an intake manifold to start cutting up to fit my eaton m112 supercharger to my 351 4v clevo.
so the question is, can i fit a 2v intake on an engine with 4v heads? and I've never really understood the differance between the two sets of heads. does 2v mean 2 valves per cylinder and 4v mean 4 valves?
any information is appreciated.
- Sean
Old 10-04-2004, 10:13 PM
mark a.'s Avatar
mark a.
mark a. is offline
No, the ports are much bigger on the 4v heads.
2v heads have smaller valves and ports than 4v heads. all cleveland heads use 2 valves per cylinder.
Old 10-04-2004, 10:27 PM
solaratomic's Avatar
solaratomic
solaratomic is offline
You're probably more used to hearing the term barrels. Four valve cleveland heads came stock with a four barrel carb or "four valve carb". Two valve heads came with a two barrel. Ford simply put high flowing heads on to match the high flowing carb. You're gonna need a 4 valve intake to match you're heads, besides all you could bolt on a 2 valve intake would be a 2 barrel and that would just not be very much fun.
Jack
Old 10-05-2004, 04:37 AM
Scopie's Avatar
Scopie
Scopie is offline
I dont want to mount a carbie on it, I'm using the 2v ior 4v intake manifold as a base to fabricate a supercharger mount.
I'll probably cut an inch or so off the top of it and weld half inch of plate steel as a base mounting plate for the blower.
Hopefully the following diagram will make sense;
......____
.....|_O_| <---- Eaton supercharger
...../___\
....\____/ <--- 2v or 4v intake manifold cut and welded
__...........__
|..\_____/...|
..|...........| <---- engine
...\______/
so will the 2v manifold fit my 4v heads?
Old 10-05-2004, 06:15 AM
solaratomic
no the ports won't match 4v ports you need to cut up a 4v intake
Old 10-05-2004, 06:16 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
No it will not.
Old 10-05-2004, 07:02 AM
Scopie's Avatar
Scopie
Scopie is offline
ah rats. well thanks for the information guys. you saved me from buying a 2v intake and trying to make it fit
ah well. 2v manifolds are $50 at the yards.. and 4v's are $200. (aus prices)
thanks again.
Old 10-05-2004, 07:08 AM
wizzard351's Avatar
wizzard351
wizzard351 is offline
on 4v head/intake you could drop a gulfball threw it the 2v intake has way to small of ports you would be defeting all that hard work by only useing half the port in the head if you was goin threw the work to modifie a intake why not just build one from scratch that way you could make shure you had the ports rite
Shadowrider123
16
09-09-2016 05:57 AM
nothercrash
08-12-2010 03:59 PM
mwsF250
Modular V10 (6.8l)
25
12-05-2008 03:13 PM
pward76
20
12-04-2003 05:27 PM
tall1
05-05-2003 04:29 AM
Quick Reply: 2v 4v intakes.. whats the differance?
