alternator regulator wiring questions
Old 09-30-2004, 07:26 PM
josmo's Avatar
josmo
josmo is offline
I converted my 64 econovan from generator to alternator
to make it easy on me i got one of those falcon regulators that mounts on the back of the alternator with red/bat,green/fld,yellow/sta and black to ground
It was working good for a while(couple of month),by the way I installed an isolator for a second battery coupleof weeks ago
Now the battery is drained over night (3 amps current drain)
I believe the regulator is kaput
There is no wiring hook up, so can somebody tell me were the I,A,S and F terminals of the ford regulator go to (like F-field ,S-stator on the alternator etc.)and alternator wire ,too
Old 09-30-2004, 08:55 PM
Jimbare's Avatar
Jimbare
Jimbare is offline
all alone in the world
sorry, been buysy elsewhere. i is the indicator or excitor wire from the acc side of the ign. switch thru the gen light. a is the ampmeter or bat. if you have a light. s is stator and f is feild.
see you had it right all the time.
email me or p.m. me for some econoline news.
Old 10-02-2004, 01:31 AM
josmo's Avatar
josmo
josmo is offline
the new regulator I got doesn't work do you mean the "I" terminal of the regulator has to be hooked up ? Like an exciter for the regulator to be engaged?
maybe you could give me a short instruction or refer me to a set up ?
Old 10-02-2004, 11:19 AM
Jimbare's Avatar
Jimbare
Jimbare is offline
yes the i side of the regulator is hooked to the accessorie side of the ignition switch.
if you hook it to the ignition side of the switch the truck will not shut off.
i am with out email at the moment, had a comp. crash last night. if you need anymore help just p. m. me.
ktz78
12-20-2010 11:10 PM
lemonshindig
02-24-2010 10:43 AM
f250utilityguy
01-28-2008 07:31 PM
dirtbikes987
01-21-2005 06:26 PM
78f3504x4
Electrical Systems/Wiring
05-19-2004 09:42 PM
Quick Reply: alternator regulator wiring questions
