'86 Charging Wiring - Can't find the stator wire
Bought the rig and he had cut the pigtail for the alternator off. Then, he ran the field wire into the dash to a cut-off switch, and then back out to the F terminal on the alternator via a spade connector. He explained to me that the diodes were bad so the switch needed to be on only when the engine was running otherwise the battery would drain current into the alternator.
Well, if the diodes are bad, then aren't you putting AC current into a DC system?
So I pull it out and take it into Schucks for testing. I noted that there was nothing at all hooked up to the S terminal. The alternator tested good so I looked up a wiring diagram for an '86 F-series. Has the stator wire going to the S terminal on the voltage regulator. Makes sense to me. So I start tracing the S wire from the v regulator and find that it doesn't go into the same harness as the rest of the alternator wires, it loops around (green wire) and runs through two other harnesses. I have yet to figure out exactly where it ends.
Am I missing something here? Are the charging diagrams different for diesels? Where is the stator wire?
Thanks
-Matt
Thanks
-Matt
The diesels were wired differently, and I don't have a diagram for a older diesel. But if you want to wire it this way, it will work. Just make sure your "s" wire coming from the dash does have power when you turn the key. If you verify this and it does, then you can wire like the diagram below and it should work fine. In the method below, there will be no connection to the "s" terminal on the alternator, obviously we don't have chokes.
hollywoodusmc
04-01-2016 09:56 AM
Mad tiki
15
12-14-2015 10:08 AM
Biged40
11-13-2012 09:40 PM
