6 speed transmission swap
OK, I have a 93 F-250 with a 7.3 diesel, an E4OD trans, and 4x4. I want to swap the trans for a manual and I'm thinking of getting a 6 speed from a Super Duty. My question is, will that trans bolt onto my engine and transfer case, or if not, is there an adapter I could use?
Scroll down to the botton.
ZF 5 Speed sounds easier than the 6 gears listed at the bottom.
http://www.motivegear.com/tech_info/...nny_guide.html
Sit back, open a brewski or diet coke or a plain water as would be your preference, and check out:
http://www.baumannengineering.com/e4odinf.htm
Converting to a stick is going to be a process full of joy, so you may consider beefing your auto and giving it some new brains.
Good luck.
Good luck.
newforce
09-25-2013 08:00 AM
knuckleharley
12-20-2006 08:04 AM
