propane injection?
Old 09-22-2004, 01:46 AM
fordpower2003's Avatar
fordpower2003
fordpower2003 is offline
Question propane injection?
hey guys,
i just wanted to get some input from yall and see what you thought about propane injection on a psd. Im thinking about doing it sometime in the future and would like yall to give some pros and cons about the system. if some of you already have propane i would like to hear if yall are impressed with it or not.
Thank yall much,
Ford Power 2003
Old 09-22-2004, 04:45 AM
Quadzilla's Avatar
Quadzilla
Quadzilla is offline
I've had the Powershot2000 system on my truck for over a year, and am impressed with the amount of additional power it provides. The installation is relatively easy, once you determine the tank size/location, etc. There's a true 80hp increase on a dyno. The cost of propane itself is well under $.01/mile, so the expense of operation isn't too bad.
The downside is if you have it set too high. Serious damage can occur if safe limits are exceeded. Bent rods and cracked pistons are a few of the potential dangers.
If you decide to install a system, let me know, and I can walk you through the initial "dial in" procedures.
Old 09-22-2004, 08:35 AM
farmb0y's Avatar
farmb0y
farmb0y is offline
Yea, listen to quadzilla, he knows what he's talking about. If you want to add any other mods to your truck, quadzilla has done it and can tell you how to do it! Just look at his truck in his gallery!!
Old 09-22-2004, 08:52 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
I've looked and never been able to see Quadzilla's truck. All I get is this little square with a red dot in the middle.
Old 09-22-2004, 05:50 PM
Quadzilla's Avatar
Quadzilla
Old 09-22-2004, 10:12 PM
WeWeld's Avatar
WeWeld
WeWeld is offline
The Powershot 2000 is a good system , I've had mine for 160,000 miles.
GENE
Old 09-22-2004, 11:09 PM
Kwikkordead
Originally Posted by Quadzilla
Wow, nice truck and very tricked out. I like the big exhaust. I'll bet that sounds nice and deep when you put the screws to it.
Old 09-24-2004, 08:46 PM
fordpower2003
Thank you very much for your input guys.
I will probably get propane injection after i get injectors and sell my edge products, and get a chip that will work with the injectors.
Thanks again,
Ford Power
Old 09-25-2004, 06:28 AM
Quadzilla's Avatar
Quadzilla
Just so you'll know what to expect..... If you add propane injection to a truck with stock injectors, you get a big increase in power. After adding aftermarket injectors, the amount of incremental power from propane is lower. Most of the people I know see injectors and propane as an either/or proposition. Few run both, though it's been done.
Old 09-25-2004, 09:32 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Thanks again,
Ford Power
Before you invest in another chip find out if yours can simply be reprogrammed. Save a few $$$
Old 11-21-2004, 01:29 PM
dieselfish's Avatar
dieselfish
dieselfish is offline
From Quadzilla: "If you decide to install a system, let me know, and I can walk you through the initial "dial in" procedures."
I have driven ford diesel trucks since 1983 and made many modifications on them. I have never used a propane injection yet. Due to my business, I tow RV's very long distances. I have a 4" exhaust, cold air intake system (K&N), Superchip Trimode Tuner and a full gauge system on a 1996 F250 4x4. My mileage is only 12 mpg towing and 15-18 mpg empty (automatic, 3:55 gears). I have access to a complete used Bully Dog system for a 7.3 PS. Would this be a good addition to my towing package?
jbmoi
Modular V10 (6.8l)
20
07-27-2019 05:17 AM
PaulsEdge
Alternative Fuels, Hybrids & Mileage
01-09-2017 07:09 AM
thedaddycat
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-05-2008 12:42 PM
edub32
15
04-09-2005 05:33 AM
RealMenPowerstroke!
08-31-2004 09:52 AM
Quick Reply: propane injection?
