little help if you would be so kind....
Old 07-27-2012, 06:55 PM
Tattyjoe's Avatar
Tattyjoe
Tattyjoe is offline
I have a 69 ranchero 500 with a 302, And it dies at a light if im lucky enough to get to the light but most of the time i start it and it just dies, So i cleaned the 2 barrel carb put new spark plugs in it and got a new battery and it ran good for like a day and now im back to the same problem any ideas also i put on a new air filter as well...
Old 07-27-2012, 06:59 PM
Tattyjoe's Avatar
Tattyjoe
Tattyjoe is offline
O ya and before this happened it would back fire LOUD when i was trying to get it started and go when i was in the intersection
Old 07-28-2012, 12:58 AM
Tattyjoe's Avatar
Tattyjoe
Tattyjoe is offline
nice ill try that
Old 07-28-2012, 04:36 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Check your cam chain.
Pull the distributor cap. Rotate engine by hand until the rotor moves. Reverse rotation and note how many degrees of crank rotation you get before the rotor moves. Over 5 it's a question mark, over 15 replace the timing set.
A wandering idle and backfires are clues to problems in that area.
Rudy1984F700
Large Truck
06-23-2015 02:34 AM
ndmccann
10-08-2012 01:11 PM
76fordexplorer
05-20-2009 04:13 PM
luke-gr
18
11-01-2007 03:28 PM
Justjake71
05-01-2007 08:50 PM
Quick Reply: little help if you would be so kind....
