EGR Valve Replacement Help
Old 09-13-2004, 01:33 PM
Sitka's Avatar
Sitka
Sitka is offline
Hello,
It looks like I may be replacing the EGR valve on my 1997 Expedition soon. It has the 5.4 liter engine. Seems my cresent wrench is just too small to fit the large b nut which attaches the tube going down to the exhaust. I was wondering if anyone knew the exact size of that nut? A larger cresent wrench would work, but it might get a bit tight for space. If I can find the correct wrench, it would work better.
Thanks!
Old 09-13-2004, 09:26 PM
03f150man's Avatar
03f150man
03f150man is offline
egr valves tend to get really tight due to heat and time. Invest in a set of metric wrenches and a socket wrench. Cresent wrenches dont cut it as the nuts will round off and/or not worth the extra effort compared to metric sockets. Suggest you soak the nut the night before with PB Blaster or similar. good luck
Old 09-14-2004, 01:12 AM
Sitka's Avatar
Sitka
Sitka is offline
Thanks, that's why I was trying to find the exact size. I set of metric wrenches that big would not get much use in my house, so I thought buying one would be better. Or maybe just a boxed end style crowsfoot?
Old 09-14-2004, 08:59 PM
03f150man's Avatar
03f150man
when i posted last i didnt read your message closely and i wasnt thinking about the big EGR nut. That got my curiosity up so i went out in the drive just now to check my 97 F150 4.6. The biggest metric open ended wrench i have is a 23MM and it was too small. So i tried a 1inch, a 1 1/8th, and a 1 and 1/16th standard wrench. The 1 and 1/16th inch is a very close fit. I took my egr off for cleaning some time ago and i dont remember if i used a large crescent or the 1 1/16th. You could convert the 1 1/16th inch size to metric and see what the metric equivalent is. I would guess it is a 25MM.
sorry about last night's post. i can see why you dont want to buy a set of metrics up to the big 25MMsize.
Old 02-18-2013, 10:16 AM
amateurgirl1's Avatar
amateurgirl1
amateurgirl1 is offline
'99 4.6L Ford Expedition - any tips or suggestions on getting to the darn thing and then finding the room to loosen the nut??!! on my previous car (Explorer) the EGR Valve was in the front and easy to get to....in my Expedition its in the back and I'm having a hard time maneuvering around other hoses and pipes in order to loosen the nut. thanks
Old 02-18-2013, 01:51 PM
amateurgirl1
wrench
the 10" wrench is the correct size....its getting the nut off that's the problem:-( soaked it in PB Blaster but still wont budge:-(
Old 02-24-2013, 07:34 PM
chuck_112's Avatar
chuck_112
chuck_112 is offline
A quick tip I've leaned when the size of anything is larger than I have I just go down to the parts store have them pull the part go over to the wrenches or sockets and keep trying until I find the right one. But I'm a bit lucky part store two blocks from me.m
alan.cassidy
1978 - 1996 Big Bronco
02-29-2012 08:08 PM
grostig
03-26-2008 11:36 PM
bl311
19
08-14-2006 04:49 PM
Roadhog123
08-26-2003 03:15 AM
Quick Reply: EGR Valve Replacement Help
