Oil by-pass filter system
If you have a gas fuel injected engine they are not cost effective unless going with extended oil changes and even then it is a break even deal. If you are running a diesel, there are advantages providing that you incorporate extended oil changes using oils designed for it like Amsoil or Delvac 1. It also requires getting your oil analized every 5,000 miles to check on the additive depletion. Should you decide to use one, make sure that you install a check valve that will cut the flow off of the by-pass should your oil pressure drop below 30lbs. In selecting a by-pass it is important to consider availabilty of replacement cartridges. Most by-pass units will easily filter to 3 micron. Of those that we have tested, the Amsoil and FS-2500 perform as advertized. Avoid manufacturers that have absurd claims such as their unit will reduce wear by 80%, etc. It isn't going to happen. There are others, I am sure, that we haven't tested that will do a good job as well. Best of luck in your endeavor.
Originally Posted by theoilguy
you're a jive turkey, don't hijack this thread!
But hey, if you need something to do to stay busy, go for it!
Beachbumcook
11-20-2006 03:05 PM
