p603 code and transmission OD light flashing-
Old 09-07-2004, 06:01 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Powerstrokedlariat is offline
Exclamation p603 code and transmission OD light flashing-
Help- I have just bought a 2001 F-250, 7.3, automatic with 95,000k.
First day- Tranny OD light came on and locked up in 2nd gear-
Back to dealership. Replaced speed sensor on rear diff. and sent me on my way.
30 minutes down the road and same thing happens. Computer code reads p603-
Dealership bought and installed a brand new computer for truck. I went and test drove- Still the exact same problem, and p-603 again. Dealership doesn't know what to do next so I told them I would ask you guys. Please help!
Old 09-07-2004, 06:23 PM
Byrddog's Avatar
Byrddog
Byrddog is offline
internal control module cam error - p-603
At least thats what the trany shop told me mine was.
If anyone knows what it is please let me know.
Old 09-07-2004, 06:29 PM
Powerstrokedlariat
Exclamation
My dealer is telling me that the 603 code just tells them that the battery has been unplugged. Does that sound right? I still cant drive the truck for more than 30 minutes.
Old 09-07-2004, 06:44 PM
IowaF250's Avatar
IowaF250
IowaF250 is offline
If it starts flashing while you are driving, most of the time it is indicating the tran temp is getting high. However, it will also flash if there is a problem with the tranny. Does it flash empty or when you are towing? I have had mine flash a couple times empty when it was 95+ degrees, cresting the top of a hill stopped by the time I was half way down the other side.
I'm still looking for a code link for you.... I can't find it yet, but before tonight
I'll get you something.
Cheers
Old 09-07-2004, 06:47 PM
Powerstrokedlariat
Exclamation
It happens when completely empty. Have not had the opportunity to tow with it yet. Also, the engine revs up to 1200 rpm when I put it in park, when the light is flashing. Outside temperature has been in the 70's to mid 80's. Here in the Northwest it stays fairly mild.
Old 09-07-2004, 06:49 PM
IowaF250's Avatar
IowaF250
IowaF250 is offline
P0603 — PCED Internal control module KAM error Open PCM pin, disconnect B+, faulty PCM
Cheers
Old 09-07-2004, 06:54 PM
Powerstrokedlariat
Thanks. My dealer is completely lost. Starting to worry me. Thanks again.
Old 09-07-2004, 07:02 PM
Powerstrokedlariat
Okay, dealer says they have checked all this, yet the light continues to flash after a half hour of driving. Light will quit flashing after awhile, but then will start flasshing and locks up in second gear again. Mainly when at a stoplight or any time starting off in first gear after 30 minutes.
Old 09-07-2004, 10:18 PM
Byrddog's Avatar
Byrddog
Byrddog is offline
Have they said anything about your torque converter.
because that is what what im getting is clutch slippage and temp over condition and the p-603.
Not sure what direction im going to take on this either.
Old 09-07-2004, 10:29 PM
95psd's Avatar
95psd
95psd is offline
My O.D. light was also was flashing and the tranny shop told me that the code was for torque converter slip. I did not get the code number from him though, sorry.
Old 09-08-2004, 01:05 AM
Powerstrokedlariat
I will ask them about this first thing tomorrow. They seem to be lost as I said earlier and my service advisor is waiting for calls back from Ford headquarters. Thank you very much for your help guys. Let you know when I know something
Old 09-08-2004, 05:58 AM
redbull660's Avatar
redbull660
redbull660 is offline
Ya I would like to know also, mine works fine but just in case this happens to mine Its good to know. thanks
Old 09-08-2004, 02:25 PM
long550's Avatar
long550
long550 is offline
when it locks up in second does it just not want to go to third? Will it not shift back to first? If you keep accelerating when it locks in second till you are around 3000 rpm and let off accel fast will it jump to third?
Old 09-08-2004, 06:27 PM
Powerstrokedlariat
Thumbs up
Heres the scoop. When it locks up in second, cripple/limp home mode I am told, It will shift up still, but I have to rev it up high like 3000 rpm as you noted. I can still manually down shift it with the selector. Now, the dealership has told me to come and pick up the keys as they think it is fixed. Since it is a driveability problem the want me to drive it. I asked them what they did and the technician told me that he cleaned all wiring harness connectors with some miracle cleaner. The funny thing is that before he did this we had a code P-603 on his scanner and now the code has dissappeared. I am going to drive it until I get it to act up again (if I can) and will let you know what happens. Crossing my fingers!!
Old 09-08-2004, 07:45 PM
Byrddog's Avatar
Byrddog
Byrddog is offline
If he disconnected the battery it will reset until the code is thrown again.
It takes mine a few weeks to do it again.
Quick Reply: p603 code and transmission OD light flashing-
