mid-engine F150? How do you make it work?
Old 09-07-2004, 04:56 PM
fish_bulb's Avatar
fish_bulb
fish_bulb is offline
My brother-in-law and I started work on Baja (prerunner type) F150 and I'm thinking about balancing out the weight distribution for jumping. I want to turn the engine around and put it in the bed of the truck (the fan will be pointing toward the the rear bumper and the t-case will be pointing toward the front bumper). How do I do it and still keep the driveline rotation correct? Is it done in the transfercase? If so, who makes a reverse rotation transfercase?
1973 F100 4wd
Pic Vid
http://www.ATV-Racing.com
Old 09-07-2004, 06:42 PM
SoCalDesertRider's Avatar
SoCalDesertRider
SoCalDesertRider is offline
Sounds like you will need a V-drive unit from a boat to reverse the direction of the rear driveshaft after the transmission. What you're contemplating is actually more of a rear engine than a mid engine, since the engine will likely end up being over the rear axle.
Old 09-08-2004, 03:11 AM
rebocardo's Avatar
rebocardo
rebocardo is offline
Maybe it is me, but, I would never want an engine behind me in a truck I was jumping for that 1% of the time when everything goes wrong. It was the main reason I never bought a small mid/rear engine car no matter how neat.
Old 09-08-2004, 09:41 AM
fish_bulb's Avatar
fish_bulb
I would never want an engine behind me in a truck I was jumping...
What kind of things could go wrong? Is there a safety issue I'm over-looking?
Looks like SCS Gear makes the units for the monster trucks. I imagine they are crazy expensive.
Ben
__________________
1973 F100 4wd
Pic Vid
Old 09-27-2004, 10:34 PM
furball69's Avatar
furball69
furball69 is offline
Edit:
Hook everything up as normal then flip the diff over so it goes the other way.
*Actually if it's a 2wd baha, as most are, running the actual rear diff from the transfer case wouldn't work unless the pinion was offset so the v-drive from transmission output would probably be the best way. You still may need to flip the diff over though.
Old 09-29-2004, 05:21 AM
wyldstallyn73's Avatar
wyldstallyn73
wyldstallyn73 is offline
I dont remember why I was thinking about doing that same setup, but I came up with the idea of building my own t-case using only two gears. That would reverse the direction of rotation, but you would only have a single speed. I already saved the sprockets from two NP 203 t-cases to try to use as gears, and then build the case around them.
HRTKD
Toy Hauler Towing; Fifth Wheel & Bumper Pull
21
05-24-2017 10:40 PM
Mickey Bitsko
1997 - 2003 F150
03-10-2017 03:33 PM
mjstef
1999 to 2016 Super Duty
09-19-2016 10:49 AM
System
35
05-06-2010 11:29 AM
7mpg302
12-01-2008 06:26 PM
Quick Reply: mid-engine F150? How do you make it work?
