223 stuck what next?
Hi I have a 1954 f100 with 223 and 3spd. motor is stuck. I tried the marvel mystery oil but no luck yet . What's the best way to go with out puttin alot of money in it? Im goin for a fifties hot rod look , wanted to keep engine original but if not so be it. I have extra body parts if anyone needs any . Thanks
Have a look at this link to a thread from a few days ago. It's exactly what you're looking for.
https://www.ford-trucks.com/forums/s...d.php?t=274916
With the plugs out that long, though, I wouldn't get my hopes up too high.
ROB
ROB
I had an olds 425 engine that I could not get broke loose that had set for seven years without running. I tried every penetrating stuff that you can think of. Finally I pulled the engine, removed the crank and took a block of oak and four pound sledge and drove the pistons out the bottom of the block,,,last resort. It was only one or two that were frozen in the block.
bob
bob
wdmack
03-04-2012 06:20 PM
fordmanforlife246
16
03-05-2011 02:29 AM
sleddog60
04-17-2009 05:43 PM
bjarnold1
30
01-01-2009 06:41 PM
