Rear End Whine?
most likely it is low on gear oil. there may be some damage such as excessive wear due to low oil level. overheating may have also occurred which could cause cracks or breakage in the gears. if it is low you need to try to find where it is leaking and fix it asap. you may be ok with fixing the leak and filling the rearend up with new oil. i hope this helps some. good luck, Eddie II
dscanlon
01-24-2022 07:33 PM
calvinbjr
1999 to 2016 Super Duty
26
08-11-2009 03:47 PM
