The 425HP 6.1 HEMI is due out next spring!
#46
#47
#48
Originally Posted by Crazy001
Ben, you realize that the quote you mentioned says "naturally aspirated". This means no turbo, no supercharger, etc.
Someone else then brought up forced induction, and I mentioned that several turbo cars made more, such as the late eagle talon 2.0L (4G63 mitsu), at 105 hp/liter.
#49
#50
I know a '79 Trans Am with the 403 big block only turns 220! Those old V8s were hugely inefficient, and didn't turn much power! The 305 they put in the T/As starting in 1980 only turned 150 HP. I could get a Neon to do more than that without much trouble!
#51
You're defniitely correct about that. I used that analogy because that's the only HP figure I came up with for old carburated V8s. I realize there is much more than HP, but the point still remains that the old V8s were nowhere near as efficient as today's fuel-injected engines. I read somewhere that sometimes the mixture was so rich on some of the carbureted engines that you could ignite the exhaust! A carbureted engine will never retain a perfect mixture, and unless it's tuned often, it won't come close.
#52
#53
#54
Originally Posted by rockclimber
The power density (or specific power output) discussed refers to V8s. It becomes increasingly difficult to keep power density up as displacement goes up. So the new 370ci HEMI has the corporations highest power density (V8s). Very impressive numbers for a cam-in-block engine.
#55
Originally Posted by benwantland
I'd also like to comment on the "specific output" issue.... my Dodge Avenger (which is a POS dog) has a 2.0 L four cylinder that is rated at 140 HP. That is 70 horses per liter, which is essentially the same (but incrementally more, if we're splitting hairs) as this new engine.
And, if turbo engines get into it, I believe the second gen eagle talon had 210 horses from a 2.0L 4G63, which would be 105 hp/liter.
Those people need to get their facts straight.
Hmmmm...... These people need to get their facts straight? Both cars you mentioned were made by MITSUBISHI, not DC.
#56
#57
Originally Posted by daimon1054
I just read a test of the Dodge Magnum with the Humy sorry Shimy dang Hemi and in a car with a 5 speed auto and cylinder deactivation it got like 15 MPG. That thing must such in a truck and this HO motor will be even worse.
#59
Originally Posted by Toreador_Diesel
That is alot of horsepower! In fact, I think it's over kill. Just imagine what kind of mileage the engine would get if stuffed it in the ram!
Man , you get Smileage with that combo !
Over kill ???????
Never TOO MUCH POWER !!
same as my old Boss 9 in my truck ....
Ford best up their Lightning if this makes it to the truck line ... this motor would be great in the Ram Rumble Bee truck ...
#60
Originally Posted by Fordtastic
Hey BigRyan. I have also read Mention of that new Ford 6.2L. Also read that it was also still in early planning stages...but any word if it will have a Hemispherical design? I know they had one back in the '60s i think even before the Dodge.
yes , Ford had 2 V8 Hemis ...
the 427 "Cammer" and the Boss 429 ....
I ran a Boss 9 in a truck , truly wicked ....
I'm building another for my 78 F150 , but , if Ford has a 6.2 DOHC crate motor in the works (I'm looking real hard at the 5.0 DOHC crate motor , cheaper than a Boss9 to build
hmmmmmmmmmmm,....
CTford
Ford vs The Competition
49
12-09-2004 12:59 PM
