04 Excursion 20 pin connector DVD HELP!!!!
Old 08-12-2004, 04:46 PM
EightSecV6's Avatar
EightSecV6
EightSecV6 is offline
I have an overhead DVD player from a wrecked 04 Excursion, I want to install it into my 04 F350. It has a 20 pin connector, I cannot find any wiring info on it, even from the dealer. The 12 pin deal seems to be an easy install using an FM modulator, I suppose the addl. wires are for the wireless headphones. Any ideas from anyone?
Old 08-12-2004, 07:52 PM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
Is it a dealer installed DVD or Factory installed?
Old 08-12-2004, 08:26 PM
EightSecV6's Avatar
EightSecV6
It was factory installed in the Excursion, I have the unit that hangs from the headlined and I want to put it in my F350, that is why I need the wiring info.
Old 08-12-2004, 08:40 PM
HomerWinzlow
Old 08-12-2004, 08:51 PM
EightSecV6's Avatar
EightSecV6
WOW, looks like the illumination, power and ground wont be a problem, I will still have to figure out how to wire everything in, will an FM modulator work????
Thanks for the help,
Bill
Old 08-12-2004, 08:54 PM
HomerWinzlow
I dont know, I dont play with riggings, just the factory original stuff... its plenty of work just to keep the original stuff working.. LOL
Im sure there are a lot of people who have done something similar on this forum. The only thing I see you may have a problem with is the ACP protocol network, but Im sure someone knows a work around.
Old 08-12-2004, 09:02 PM
EightSecV6's Avatar
EightSecV6
Do you have anything that gives a description of the remaining wires or do you know if there is just a factory harness I could get from the dealer?
Thanks for your time!
Old 08-12-2004, 09:08 PM
HomerWinzlow
Most factory harnesses these days come with the headliner. Its glued down to the headliner. That page was the only page shown for the DVD. Now I know the dealer installed unit has two connectors, one on each side of the unit. It is an all black unit. Factory has a large plastic console almost the width of the headliner on Excursions that I have seen and color keyed to the headliner. The dealer installed unit is only about 12 inches by 18 inches.
If it were a dealer installed unit you could probably get a wiring loom from the dealer and yes it uses an FM modulator.
Old 08-13-2004, 01:46 PM
EightSecV6's Avatar
EightSecV6
can anyone tell me what those sideways "figure 8" symbols on the drawing mean?
Old 08-13-2004, 06:06 PM
HomerWinzlow
It indicates a twisted pair to reduce crosstalk and interferance.
Old 08-13-2004, 06:20 PM
EightSecV6's Avatar
EightSecV6
does it look like 16 and 18 are together as one connection as well as 6 and 8, 15 and 17, 5 and 7.
mcne2026
11-04-2009 10:52 PM
shabazz018
1997-2006 Expedition & Navigator
06-13-2009 12:07 PM
stocktonlariat
03-11-2005 10:56 PM
EightSecV6
08-19-2004 07:34 AM
Quick Reply: 04 Excursion 20 pin connector DVD HELP!!!!
