A/c
You need to check the vent temps.. My 04 Lariat is blowing at 56-58 degrees. That's not AC... should be in the low 40's.. I'm only at 700 miles and it's first on list when I get the oil changed at 1000 miles next week. If they can't cure it I can.. I did my 88 Bronco with Enviro-Safe, of course after a new compressor, dryer, evaporater and valve. It's a direct change over to R-134 or R-12. Cold....like you read about... I can hang a wet rag in front of the vents on the Bronco and it will stiffen. Vent temps at 31-32 degrees. We're talking headache cold...with outside temps in the 90's..
I have the automatic system and I've noticed that sometimes the air coming out is very cold when the truck is just started in hot weather and the fan is commanded to be on full blast. Then, after the interior cools down some and the fan speed lowers, the air coming out is just barley cool. This afternoon, I put it in manual mode, turned the fan to about medium, put recirculate on and set the temp to 60 and I never could get really cold air to come out. I don't really like the air to be just cool and the fan running at 1/2 or 3/4 which seems to be the way the auto system likes to run it.
I've never had a problem with my AC, we're going on 7600 miles now. it's always cold. in fact on the hot 80-90 degree days, I usually don't even have to turn it to Max AC.
I am wondering if anyone else hears that sound coming from the engine whenever the AC is turned on. like a muffled cliking sound. I took a look, and it looks as if it's coming from the lower left corner of the serpentine belt loop (if you're looking at the engine). something there seems to start spinning and stop spinning whenever the AC is on.
Any ideas on what that is?
