Seat Brackets get HOT!
I'm usually able to search the forums and find the answers I'm looking for, and would like to thank all the posters for that. Unfortunately, I couldn't find the answer this time. Hence my first post. I own a 2004 F-350 CC PSD DRW Lariat and I am wondering if a condition with my seat brackets is normal. I took the truck on a trip from El Paso, TX to Huntington Beach, CA and along the way I put my bare foot down on top of one of the exposed metal brackets on the passenger side front seat that holds the seat to the floor and to my surprise got slightly burned by it, not severely, but enough to make me wonder why these things are not covered. Is it normal for these brackets to get this hot? Should they have covers? Any fixes?
i never noticed that myself, but the exhaust pipe does run right under the pass. seat. you could try some heat shielding on the pipe and under the carpet under the seat.
www.jegs.com sells alot of different types of heat shielding
your truck also has a cat (i think) and they will get pretty hot as well, if it is right under the seat it would heat it up pretty good.
I appreciate the replies. I have just been reminded that I shouldn't assume anything. I assumed that there would be a heat shield between the catalytic converter and the floor board, there is not. The catalytic converter sits @ 5-6 inches below one of the bolts for the seat mount. In fact the only heat shield it has is a tiny one above the muffler. I guess I'll be spending some time this weekend fabricating a heat shield for it. Already being a fan of Jegs I guess that's where I'll start looking. Hopefully Ford won't void my warranty for it.
Originally Posted by Tim Lamkin
Heat sheilds when you build them.....how will you attach it the the bottom of the truck?
Forgot to thank WLIHNTR. It was their suggestion about wrapping the pipe that made the difference. At first, I was hesitant to wrap the pipe out of fear of heat damaging the converter. The problem child at work just reminded me that I don't have to wrap the pipe, I can just stick it to the underside of the floor pan.
Last edited by EnviroCon; 08-09-2004 at 05:17 PM. Reason: Forgot to thank WLIHNTR!
RL250
07-19-2014 09:41 AM
EL_JEFE32
10-16-2012 02:54 AM
