well my friend has some mustang rims on his 92 ranger w/ a 2.3L and he didnt have to put any spacers or anything, but i dont know what the year of the 'stang was, hope this helped a little if at all lol
quack
As long as you get the 5 bolt pattern, you'll be okay. The 4 bolt pattern from 79 - 93 Mustangs will not fit. 94 and up Mustangs, and 89 and up Thunderbirds will fit. Crown Vic wheels will fit.
I have seen 17" 94 Mustang wheels on an Aerostar, so you should have no problems. Mind you, they did look a bit out of place on a minivan.
Lay a straight edge across the back of the wheels and use a tape measure to check the offset of your ranger wheels,then check the mustang wheels.as long as they are close they should work.
