95 mustang wheels on ranger
Just a quick question, will 94 and newer mustang wheels bolt up to my 93 ranger ext cab 2wd,4L? With out any problems???spacers????
well my friend has some mustang rims on his 92 ranger w/ a 2.3L and he didnt have to put any spacers or anything, but i dont know what the year of the 'stang was, hope this helped a little if at all lol
quack |
The older car pattern was the same as the early Rangers. I don't know about recent models.
Any 5 lug mustang wheel will work on a ranger. Depending on tire size you may or may not need spacers in the front.
As long as you get the 5 bolt pattern, you'll be okay. The 4 bolt pattern from 79 - 93 Mustangs will not fit. 94 and up Mustangs, and 89 and up Thunderbirds will fit. Crown Vic wheels will fit.
I have seen 17" 94 Mustang wheels on an Aerostar, so you should have no problems. Mind you, they did look a bit out of place on a minivan. |
Lay a straight edge across the back of the wheels and use a tape measure to check the offset of your ranger wheels,then check the mustang wheels.as long as they are close they should work.
