Easiest way to clean factory seat covers (removed from seat and foam pad)???
Guys,
I finally picked up a 40/20/40 seat for my 94 f150 to replace the bench. It's a little dirty and needs to be cleaned. I've pulled the covers off since the lumbar bag is busted on both. The seat is completely dis-assembled. Bare seat covers, no foam cushion pad attached.
What's the easiest way to clean the covers? Can I toss them in the washing machine? It looks like the thin foam backing might come off in the wash. Will they shrink if I let them soak in the wash and rinse them with the hose and air dry?
I'm just thinking there has to be an easier way than scrubbing a small area with the upolstery cleaner and wiping clean. Then repeating.
Any ideas?
Any ideas?
I just did this with some really dirty captain's chairs I bought. I completely disassembled the seats and took the covers off. I ran them in the clothes washer with regular laundry detergent, each seat separately (that's all that I wanted to cram in there). After they dried I was pretty disappointed. It had helped a lot, but they still looked pretty dirty. I had some Prestone automotive stain remover I used on my carpet. Good stuff. I used it on the entire covers and scrubbed at it with the brush. Then I ran each cover through a wash cycle again and let them completely dry. I put them back on and now my seats look brand new. If you'd seen them before, you'd swear I'd bought new ones. It was quite a bit of work but definately worth it.
edit: About the thin foam on the inside. It won't come off enough to matter, but there'll probably be a bunch of little "fuzzies" from it on the carpet part on the back of the bottom seat cover. They're a pita to pick out, but it's still worth it.
John,
No they didn't shrink at all in the wash. I used the warm cycle. I air dried them, I wouldn't risk putting them in the dryer.
No I didn't have any hog rings. Just undid the plastic at the bottom and the covers came off. I did take my 40/20/40 apart this spring to fix the lumbar, and I don't think it had any either. I'd have to check to be sure though.
88grandmarquis
11-11-2009 12:47 PM
