T-case/front axle 73-75 3/4 & 1 ton
Heres an outline
Weeeeeeel, what is actully in each truck can depend on a LOT of different things but what there was available is pretty straight forward. Dana 44 of course, these had bigger hubs,knuckles, spindles, and i belive the axlehouseings were larger/thicker than those available on F150 and F-100. but the axle shafts themselves were the same. the Dana 60. Quite the piece of iron they are. there were both high adn low pinion applications, with the high pinion in 77-79 trucks with the snowplow package, they also were beefed around the centersection. For t-cases, NP205, 203, (full time) i think, Borg Warner 1350 (or a similar number! i forget) i think thats it.dont hold me too it though.
Just for sake of discussion - its my understanding that between '73 and '75 that the F350 was not normally available (i.e. not special order) in 4wd form. Someone please correct me if I'm wrong.
The '73-'75 F250 (commonly referred to as the "highboy") used the Dana 44-6CF and 44-6CF-HD front axles, which were low-pinion closed-knuckle drum-brake axles built around the D44 center section that came in 3325 lb or 3550 lb GAWR's, with the primary difference being in the brakes/hubs.
The Dana 21 was a 1/2 ton case. Transfer cases for the F250 during those years were the NP 203 (maybe) and the gear driven NP 205. The NP 203 is a full-time case and relatively rare, it's not even listed in my '74 shop manual and I'm not sure it was installed between '73 and '75, I think that a majority of the trucks had the NP 205 in a divorce-mounted configuration.
Hope this helps!
Hope this helps!
Look for a metal tag that may or may not still be affixed to the diff cover. There should also be a number stamped in the webbing of the pumpkin indicating which model axle you're looking at. As a last resort you can always "eyeball" it - compare the pumpkins on the front and rear axles - if they look alike you're probably looking at two D60's - if the front is noticeably smaller then you've probably got a D44 front/D60 rear.
Originally Posted by Mattsbox99
Thats correct, the F350 4x4 wasn't even available until 1979.
I've seen all three t cases in 67-77 F250 4x4s.
Originally Posted by scottie2hottie
rakent, where at in the webbing is this number exactly- I've looked before and came up empty handed.....
Thanks
Scott
PS- I know the D60 has a '60' but does the D44 have a '44'?
Thanks
Scott
Sorry I can't be more help. If it would help, I'll try to measure the pumpkins on my truck when I can get a chance to get underneath.
Andrew
Greg, it is possible that you have a D70 rear. I've only seen these on F350s, we have a 74 F350, that is a super camper special, they only came with D70s. A lot of F250s came with Dana 61s, this was fords "Mile Maker" axle, and was offered in 3.07, 3.3, & 3.73 ratios... Its usually seen on camper special trucks.
AzTruckin
15
12-28-2016 09:28 PM
77429highboy
07-13-2011 05:13 AM
frdavid
03-23-2009 09:55 PM
projectdagger
18
11-03-2007 02:24 PM
