Alternator wiring help
I am new to this site and am rewiring a1956 F100. I need help with the alternator wiring. The only scematic's I have shows just the old generator/voltage regulator wiring. The new alternator is a GM ibe wire alternator with a built in regulator.
Could use any help!!
1 Wire alternator wiring
I installed 1-wire alternators on my 64 F100 292 V-8 (it had a 12V generator) & my 55 Customline 272 V-8 (replaced a 6V generator with a 6V alternator).
The simpleist way I could figure out to do it is to use the wiring from the voltage regulator to the generator, connecting the heaviest (yellow) wire and tape off the ends of the others. At the voltage regulator, I bypassed the regulator, using it as a terminal strip, by changing the heavy yellow wire from the alternator to connect at the same terminal as the one that goes to the under-dash wiring. I left the other wiring connected to the regulator as they were.
To prevent the battery light on the instrument panel glowing all the time, I removed the bulb. I installed an ammeter in series in the line between the termination on the light switch and the starter switch.
Good luck.
Good luck.
maximumd93
03-11-2013 09:52 AM
wsnead56
24
09-05-2011 08:29 PM
ktz78
12-20-2010 11:10 PM
steppentex
05-23-2005 08:16 PM
steveneashcraft
12-04-2004 10:19 PM
