Weight of 1966 Ranchero
Just in case any else is looking for weight specifications for Ford's, I found a site which has a large data base. Whether the DMV will take it's information or not is still a question. The site is at http://carnut.com/ and click on Car Specs.
I had the same problem last year when I moved my Ranchero from Colorado to California. They wouldn't even take the weight off of my Colorado registration. After they told me I had to have it weighed I found out that the Ranchero's stated weight on my old title was a few hundred pounds above the weight break for the lowest comercial plate rate. Since they wouldn't take the stated weight I made sure to take everything out of the car, ran it to just above an empty tank, removed the bumpers, the tail gate, the bolt in panel in the bed, and the hood. When I took it to the truck scales to get a certified weight (they did provide a list of accepted cert scale locations) I cleared the maximum weight for the lowest price commercial plate by about 30 lbs. I look at it as a way to recoup the $20 it cost to have the thing weighed. As a bonus I'll save DMV fees as long as I own the ranchero.
If you are local to the Sacramento area I could find my scale certification and give you a copy to take in...
Kirk
Kirk
danlee
06-17-2008 06:10 AM
