Crack in the steering box mounting surface
I was out wheeling Saturday, and as I tried to put my drivers side tire up over an obstacle, I heard this terrible sound. I backed up, and noticed that the 4wd was still working fine. So I checked it when I got home. My '81 has an extra support bracket welded inside the frame to create more strength. Well, all the rocks here in AZ finally decided to crack that bracket from the bottom, about half way up. What is the best solution? Should I just weld up the crack on both sides, or do I need to add some more steel?
While we're on this subject, what can I do to beef up the steering linkage on the TTB?
I would look for kits, I know some companies sell a plate to beef up the Chevy steering box mount. I think some make them for Ford. If I was you I would just weld on some more steel to reinforce it thats esentially what the kits come with. A cut piece of steel that you weld on to beef up that area of the frame. I would look at bulletproof steering for beefy steering linkages. It aint cheap but if your in the rocks alot it may be worth it.
Thanks Lucas. You can always bolt the plate to your frame with grade 8 hardware too, if your not comfortable with welding it in. Truth is though, you can weld on your frame without fatiguing it provided you take the necessary steps such as preheating and shot peening the welds to relieve the stress risors. We ususally don't see this problem near as much as the chivy boys...
gee this sounds awfully familiar, lol. if you put hydro assist on your truck it will alleviate a LOT of stress off the box and reinforcment will not be required. a ram is only about $85 and the hoses are another $50 or so depending on who you know, lol. i am about to do this for my rig.
-cutts-
-cutts-
BigMacWelds
1999 to 2016 Super Duty
01-09-2019 06:45 PM
ChugginAlong
03-08-2012 12:32 PM
reynard101
26
02-26-2010 07:01 PM
