blowin the fuse
blowin the fuse
for any of you out there that are gifted in wiring ive got a bit of a problem. i am blowing the fuse to my turn signals, so i installed a new turn signal switch. im still blowing the fuse and have no idea where to look. i have checked to see if there are any exposed or broken wires and couldnt find any, unless i missed it somewhere. any suggestions or ideas?
Sounds like one of your hot leads is grounding out.
There may be a better way, but I'd go to each turn signal bulb, pull the bulb. Use a volt meter (continuity checker) to see which lamp hot connection shorts to ground. Once you find the bulb, follow the wire back until you find the short. I assume it only blows the fuse after you turn on a blinker.
the hot should be in the bottom center of the bulb holder, the outside will be the ground.
hope that helps...
hope that helps...
Charlie01
12-18-2010 04:16 PM
RFT
10-27-2004 05:19 PM
