I need Help
Old 07-19-2004, 03:59 PM
FrdRanger01's Avatar
FrdRanger01
FrdRanger01 is offline
I need Help
This is my problem i have pretty small budget but i want to upgrade the horse power on my 1997 Ranger 2.3L. If anyone can give me some tips on what will actaully help out i would really appreciate it. Thanks in advance for any help you guys can give me.
Old 07-20-2004, 04:08 PM
Asterrion's Avatar
Asterrion
Asterrion is offline
Post
Intake and exhaust, not necessarily in that order. the biggest gain I had before the computer was the exhaust. and removing restrictions from the intake.. after that when my power steering pump exploded (yes exploded long story) I yanked it to replace it and discovered that the truck gained all sorts of pep, so i never replaced it.
above all this all I can say is what I tell everyone, CLEAN your throttle body and do a good solid tune-up then start the mods..
Old 07-20-2004, 11:25 PM
FrdRanger01
will installing throttle body spacer increase speed off the line or not sorry if these questions are common knowledge but i am just starting to work on cars and trying to get as much info as i can
Old 07-21-2004, 12:05 PM
Asterrion's Avatar
Asterrion
I used one once, on another truck. it made no discernable difference then again if I remember correctly the spacers are generally used for Carburetor and CFI (central fuel injection (injectors in the throttle body)) not MPI like the other truck. although if you get one with a spiral pattern I hear they can boost fuel economy.
Old 07-21-2004, 01:22 PM
ranger_man1985's Avatar
ranger_man1985
ranger_man1985 is offline
Put some good gears in it. 4.11's would be good (Unless you already have 4.11's). It won’t increase horse power, but will increase torque at the wheels for more giddy up and go.
makthenif
1997-2006 Expedition & Navigator
03-26-2013 04:56 PM
tin-man
10-02-2008 01:02 AM
Monty06
03-08-2006 01:43 AM
ona6day
06-03-2004 12:15 PM
Sean_2
01-10-2000 09:09 PM
Quick Reply: I need Help
