Front end (D44) swap question
Old 07-05-2004, 09:39 PM
longview1's Avatar
longview1
longview1 is offline
Im wondering for when I do go to put a d60 in the rear of my truck, Is it possible to take the inners of a d44 ffrom a 3/4 ton truck and out in my half ton d44? Or just the ring and pinion. Or would it just be simpler for me to buy the correct gearing for the 1/2 ton d44.
thanks guys.
I asked a buddy and he said no because the 1/2 d44 is high pinion reverse cut or something.
Old 07-05-2004, 09:45 PM
ranger429's Avatar
ranger429
ranger429 is offline
I don't understand your question? You are talking about swapping gear's from a Dana 44 over to a Dana 60?
dana 60 and Dana 44 part's are not interchangeable.
Old 07-05-2004, 10:16 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I know what he's talking about - what year? Not that I know which is which, but it does make a difference, I'm sure ...
The reverse cut/high pinion (I think) is different than the standard low-slung pinion gears.
Don't know how accurate, but here's a quicky google link:
http://groups.google.com/groups?q=fo...ich.edu&rnum=1
Tend to believe it, give or take a year or two...
Old 07-05-2004, 10:26 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
thanks guys.
It is my understanding (of course I could be wrong...have been before), that the d44 is the same for both half and 3/4 tons. The only difference is the outer. But the inner gears and ring and pinion are the same. Of course that being said...they do have to be both high-pinion or low-pinion.
Old 07-06-2004, 02:11 AM
longview1's Avatar
longview1
Yeah, thats right.
Id want to take the stock 4.10 gears from a 3/4 dana 44 and put them in my 1/2 dana44 to match the dana 60's 4.10 gears in the back.
Oh, its a 78' btw.
Old 07-06-2004, 08:55 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
My stock highboy 3550 lbs front-end had a 4.09 gear in the front. Just a word of warning
Old 07-06-2004, 10:34 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Yeah, thats right.
Oh, its a 78' btw.
You should be fine...as long as both D44's are the same high or low pinion. Also, if the gears turn out to be 4.09's like Krewat...no problem. You can certainly run them with 4.10's out back. Good luck with it!
Old 07-15-2004, 01:24 AM
longview1's Avatar
longview1
Every dana 44 in a 3/4 ton ford ive seen has been low pinion.
So all said I cannot take just the ring an pinion from a low pinion and toss it in my hi pinion , cause the gear pattern or what not is different.
Id have to take the gearing from a fellow hi pinion.
thanks guys
Old 07-15-2004, 11:53 AM
RTM's Avatar
RTM
RTM is offline
I believe that after 74 or 77.5 all HD 8 lug 44's were HP. I have one at home sitting in a pile of axles.
Old 07-29-2004, 09:31 PM
RedXL's Avatar
RedXL
RedXL is offline
I have a 76 Dana 44 HD that is low pinion. I believe that all the 3/4 ton axles up to 76 were low pinion and standard rotation. Apparently a low pinion and a high pinion were available in 77. In 78 and 79 all 3/4 ton axles were high pinion reverse rotation. You can't interchange high pinion reverse rotation gears with low pinion gears cause they're standard rotation.
Hope this helps
Ray
Old 07-29-2004, 11:26 PM
fordmudrunner2020's Avatar
fordmudrunner2020
fordmudrunner2020 is offline
The axle that is in the rear of your truck should be a 9". They are pretty strong as it is. Plus you would have to convert your front axle to eight lug unless you felt like having 5 lug front and 8 lug rear rims.
pintoches
Offroad & 4x4
12-16-2011 04:07 PM
Snowking
04-24-2006 11:41 PM
supercab4x4dually
04-10-2005 06:21 PM
Sycostang67
09-23-2004 03:54 AM
longview1
01-29-2004 01:30 PM
Quick Reply: Front end (D44) swap question
