Courier swap suggestions
Other than the typical "just burn the courier to the ground" suggestion, does anyone have any ideas / experience with this? I would like some more meat under the hood, but in order to avoid major suspension stress issues caused by a v6, I was thinking aboout using a turbo 2.3 from a thunderbird or mustang. Sound completely crazy or doable? Any and all input appreciated.
its starting life as a 1.8l 4spd manual
on
73tank, what year Courier? Some Couriers in the early eighties or thereabouts actually came with the 2.3, so the mounts are available. It can be done as almost a bolt-in, I should think. Quite a number of people have put the 2.3 turbo into Rangers, so why not a Courier? I have two 2.3 turbos just sitting, was thinking of building a turbo motor but I don't know what I'd put it in at this point...maybe one of my parts trucks. Well, if you don't do the swap, you could alway burn the truck to the ground...! -TD
I have a friend who sold one about six months ago... he had shoved in 88 or 89 mustang running gear all around. Suspension, brakes, 5.0 powertrain, EFI, the works. It was a TON of fun to drive.... very quick. I believe that the courier is lighter than the modern day mustang...
What my friend did certainly wasn't something everyone would want to embark on, however after two years of working his butt off (all the way to the clearcoat) he had a really fun to drive, original looking truck that you don't see often.
I like weird stuff, what can I say...
on
Well, you would want the complete 2.3 Turbo motor, it has stronger internals than a regular 2.3, maybe the intercooler that was used on some, all EFI wiring, sensors, computer, etc. and someone to help wire it up if you're not familiar with wiring an EFI system into a formerly carb'ed vehicle. The wiring would probably be the biggest hassle, although there might be exhaust clearance problems to sort out. Sounds like fun, keep us posted. -TD
ss0345
08-15-2015 09:34 AM
