Air leaking/blowing in from under the dash
Has anyone had issues with air leaking/blowing in from under the dash. I have air coming in from under the dash on the passenger’s side. I had my dealer take a look at the problem. They’re telling me that the problem is in the “air blending box”. Evidently the blending door that allows outside air into the cabin does not close correctly. They found this on all other trucks that they checked on their lot. They then called Ford tech. They said that Ford tech is aware of the issue but does not have a fix for the problem. Their answer was to turn on some warm air during the winter months.
I’m not going for this solution and plan to start the process of returning the vehicle.
P.S. Other than this issue, I love the truck.
Thoughts/comments/help?
Thanks,
Thanks,
Well, here’s the deal. The service department is telling me that the “blender box” door doesn’t seal completely. This allows outside air to leak/blow through the assembly. They took a new blender box assembly from stock and noted that it had the same issue. Then they tested several trucks on their lot and found the same problem. That’s when they called Ford tech for advice. I would have thought they were full of crap in regards to there being no fix. But as soon as I asked about returning the truck, they put me directly in touch with Ford customer service. Would they do that if they were giving me the run around? So, the process has started. I’m willing to except any reasonable remedy including waiting for a recall if they have one in the works. But I can‘t see keeping a 40K truck that has a known design flaw that I was not informed of prior to purchase. It’s just too much money for me to blow off and it’s uncomfortable for passangers.
Could some of you other folks have a passenger reach up under the passenger side dash (below the glove box) and see if you have the leak? Highway speeds seem to be the worst.
By the way, the truck is a “screw” Lariat with the console and the six disk changer.
Thanks for the help.
Hmmm, my fiancee never said anything about cold air blowing on her legs/feet this past winter. I'll have to have her check it out sometime this weekend. Could this only be an issue on the trucks with a center console? I would imagine that they would use the same blender box on all models. But, who knows...
I have an XLT Scab, w/out console, but have the 6 disk changer.
ralupien, yes, I have a scab with the same problem. I only noticed in the winter though. As a passenger, I have to keep my feet to the top left of the floor just to keep them warm. But now that I think about it, maybe that's why the truck doesn't cool enough with the AC on. It seems to blow out of the vents plenty cold but the cab area doesn't ever seem to get to temp. 99.9% of the time, I have the A/C cranked down to the max. Hmmmm.
Well, I just got off the phone with a Ford customer service rep. He conformed that the leak was most likely what he deemed “a normal operating characteristic” of the vehicle. I pointed out that it was an “operating characteristic” of the vehicle but that it was not normal. He told me that I should get another opinion at another dealer. He also said that he would forward the information to the engineering department. He said that if enough owners complained that a fix (recall) would most likely be the result. Sounded like a canned response though.
Talked to the service manager at my dealer. She said the same thin as the Ford analyst. Basically that the air flow issue is normal and meant to vent the cab so that occupants don’t suffocate. You believe that crap. So, as far as the dealer goes it’s eat sh-t and bark at the moon. I’m going to start the issue resolution process with Ford. I don’t really expect to get this fixed and I don’t expect that they’ll take the truck back but I’m going to follow all the steps and see where it takes me. I may buy a blending box out of stock and fix the thing my self and have them install it. Who knows.
