94 explorer won't shift when hot
I recently purchased a 94 ford explorer xlt, manually trans. 4x4.
After driving for a while, especially when it is hot out, I can not shift into 1st or 2nd gear. No problems when it's cool out or when I first start out. I just noticed that the overflow container has brown water in it. Any idea what could be happening? Going to flush the radiator fluid tomorrow.
Shifting problems when hot
Hey everyone,
I had this same problem in my 94 XLT.
After finding a post in these forums discussing problems with the firewall flexing around the clutch reservoir when depressing the clutch pedal, I inspected my own.
In my case one of the mounting bolts for the reservoir was loose giving it some room to move when the pedal was depressed resulting in not enough hydraulic pressure to move the clutch to fully disengage. Tightening it up fixed the problem for me. I have also read that if the problem is in the firewall flexing (resulting in the same thing happening) then there is a bolt on plate to stiffen up that area.
Infosponge
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
06-15-2016 10:46 PM
Auburn
11-06-2005 05:43 PM
pcgold
09-20-2001 05:49 AM
