Engine Ping 1997 T-Bird Help!!!
I own a 97 T-Bird with the V-6 Motor. My problem exists only when the car is traveling up a grade and is at 2000 rpmsor above. The problem is a bad ping. on flat grade it runs great. No fault code detected. My 93 with the same motor never did it it has 186,000 miles on the original motor. I run the same mix of gas in both, mid grade and stp octane boost.EGR valve?h2o sensor? Im stumped.Can anyone lead me in the right direction. I dont want to chase this problem with many extra expenses. Thanks. By the way the 97 has 90,000 original miles on it.
A well tuned gnition is important. When is the last time you installed new double platinum plugs and a new wires on it?
A lean running engine can result in pinging. Check for any vacuum leaks, cracked hoses, etc. Replace the PCV valve with a Motorcraft brand (best fit). When is the last time the fuel filter was replaced? How about the fuel injectors ...do you run a bottle of cleaner through the system every now and then?
You might also try cleaning the MAF:
https://www.ford-trucks.com/forums/s...hreadid=126093
