Tach Install - 300 I6
I bought this tach and I'm waiting on it to arrive right now.Before it gets here,I want to be sure that I know how to install it so I can get it in immediately .
It's going to come with four wires,one power source,one ground,one illumination,and one for the tach signal.I have a question about the illumination and the tach signal.
Illumination -
I want the tach to light up as soon as my headlights are on.It doesn't have to come on with the markers...Just the headlights.Which color-coded wire coming out of the headlight switch will I need to splice into for the signal to illuminate my tach?
Tach Signal -
I'm installing this on the F-150 in my signature.Where will I need to put the tach signal wire,(i.e. the distributor,the ignition module,etc.).
Thanks for any insight.
Nightrain
Illumination -
Tach Signal -
Nightrain
Originally Posted by bigreave
when i did my i spliced into the main headlight switch for light . For your tach source i ran off the negative side of the coil green wire i think been a whil but mine is a 85
Originally Posted by 82F100SWB
Yup, green(negative) wire coming off the coil is the signal source.
For your lighting, look for a blue wire with red tracer under the dash(there's one going to the light just above the wiper switch) that'll hook you into the dash lighting, dimmer and all.
Thanks fellas .
Nightrain
Okay...My tach came in today.I think that I've found the wires for the tach signal,(Green wire on coil),and the illumination,(Blue/Red wire under dash).
But,I have a question about my power and ground wires,(Red and Black).I'm thinking of just running them to the pos and neg side of the battery.Is this a good idea?Or,do I need to find a power wire that only gets juice when the key is turned on?If so,which wire in the fuse box will only have power when the key is turned on?
Thanks for any insight .
Nightrain
Nightrain
I got my 'ol tach in .
It was a simple install.I ran the red wire to the positive side of my battery,the ground to a little ground bolt in the cab,under the radio and A/C-Heater controls,the green wire to the green wire on the coil,and the white wire to the Blue/Red wire.Everything works great,although I haven't been able to check the light in the tach yet.I'll have to wait until it gets dark so I can see it .
Thanks alot for the help,as always .
Nightrain
Nightrain
quakerj
06-27-2013 12:27 PM
Zebich
02-20-2005 10:20 PM
Nightrain
12-24-2004 10:01 AM
