1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
help connecting an amp to factory radio
Old 05-24-2004, 01:17 PM
jussam's Avatar
jussam
jussam is offline
i have a 2004 expy factory radio audiofile w/ 6 cd and want to add an amp, does anybody know if it has (rca output) or what is the best way to connect an amp to a factory radio or rear wiring diagram
Old 05-24-2004, 01:22 PM
boxdoc2's Avatar
boxdoc2
boxdoc2 is offline
I looked into doing that with my 97 Expy and was told it shouldn't be done. Can't remember exactly why, but I believe it had to do with the wrong amps or volts or something. Someone else can probably provide a better explanation. But I'm pretty sure you would need to replace the head unit and then hook up your new amp.
Old 05-24-2004, 02:57 PM
buzzard's Avatar
buzzard
buzzard is offline
I installed an aftermarket amp in my '00. The stock head unit didn't have RCA outs so we had to install converters. No big deal, just added a few bucks to the price.
Old 05-24-2004, 03:28 PM
fordborn's Avatar
fordborn
fordborn is offline
Probably said that because it had factory premium sound. The factory amp should be taken out of the system when installing an aftermarket amp. Other than that it should be fine.
Old 05-24-2004, 04:24 PM
boxdoc2's Avatar
boxdoc2
boxdoc2 is offline
Yes, it was the Mach system. So if I removed the current amp, I could upgrade?
Old 05-24-2004, 04:28 PM
fordborn's Avatar
fordborn
fordborn is offline
Yes you can add aftermarket amp to your system. As long as you have taken the factory amp out. The wiring will be different at the speakers but if you are adding a new amp you will probably upgrade the wiring also.
Old 05-24-2004, 04:54 PM
jussam's Avatar
jussam
jussam is offline
thank you all great help
abyars111
04-09-2017 10:39 PM
angeldiaz215
2004 - 2008 F150
03-24-2016 09:59 PM
abyars111
12-03-2015 08:22 PM
jfarmer
08-08-2005 09:11 PM
Quick Reply: help connecting an amp to factory radio
