According to the VECI lable (bottom of hood) it's OBD II compliant. What type of scanner do you have. Let me know if it works. I receive "LINK ERROR" when trying to connect my new OBD II code scanner (actron cp9135). It works perfectly on several other cars/trucks.
The 04 F150 uses a new way to talk to the computer. It is called canbuss. If your scanner is not canbuss ready it will not read. Link error is what you will get.Canbuss scanners are expensive. $300.00 to$400.00.
Hope this helps.
