Seal on the intake manifold
I am looking for the best way to seal the intake manifold on my 352, I am using the stock cast iron intake and the stock cast iron heads, I have tried using the gaskets from the rebuild kit and sealing them with gasket sealer, and it still poured oil out, so then I tried just using silicone, and it leaked even worse, what have you used in the past that has worked, I want it to be completely leak free.
I always try to dry fit the intake before installing the cork end seals. That way you know how much clearance you have and know that they won't slip/push out. I know that's alot to ask for a cast intake, but it makes a better fit.
Like Ratsmoker mentioned, make sure you get some silicone at the corners to seal where the drain holes are in the corners of the heads.
If using the cork ends, put a small amount of silicone down to help hold them in place, but not so much that it tries to push them out when you put intake on. Let it set up a bit(so they don't move easily). Put nice dab on each corner before installing intake.
Glad to say that's the ONLY place my FE's dont seem to leak
twobitranch
11-13-2006 10:08 PM
ggadwa
04-24-2006 09:57 AM
barca_texas
03-12-2005 10:37 PM
Supercab
09-20-2000 01:52 PM
