Anybody know wher I can get some info on installing power brakes?I have all I need to install discs but cant find any how to as far as the booster goes,what year,parts needed ,etc.
Thanks,
Patrick
I did use my original master cylinder. You will have to pull out the rod that sticks out the back and connects to the brake pedal, and push it into the booster if the booster doesn't already have one. It pulls out really hard, but it does pull out. Hope this helps!
If I remember right, the rod was very difficult to pull out. Years of corrosion maybe? It was a few years ago when I did this, but I'm sure the procedure probably involved a bench vise and 2 lb hammer.
