Slight clunk/jerk at takeoff
Old 05-09-2004, 11:28 PM
baja_stx's Avatar
baja_stx
baja_stx is offline
2004 F-150 4X4 Lariat SCAB 3.73LS
Just have nearly 700 miles now. I cold me nit-picking, but I've been noticing a slight clunk in the driveline when I takeoff from a dead stop. I can't tell if it's coming from the rear end, transmission, or driveshaft. It does NOT feel like trans shudder though... thankfully.
Has anyone else had this issue and have any of you had it repaired? If I had to guess I'd say it was the driveshaft slip yoke, but I'm not positive.
Old 05-10-2004, 07:45 AM
eyounger's Avatar
eyounger
eyounger is offline
My truck had a "shudder" on take off. Happened only if the truck had been sitting for a while.
I took it to Planet Ford where BJ had it checked out. Turns out my clutch packs needed to be replaced.
BTW my 04 has 6200 miles on it.
Old 05-10-2004, 08:07 AM
NC Sean's Avatar
NC Sean
NC Sean is offline
Baja stx,
I had the same clunk when I took off from a dead stop. I took it to the dealership and they greased the slip yoke due to the fact that it was not properly greased at the factory. The service manager also said it is a common problem. I have not had anymore problems since.
Old 05-10-2004, 08:34 AM
Jim Brock's Avatar
Jim Brock
Jim Brock is offline
Is there a TSB for the slip yoke?
Old 05-10-2004, 12:48 PM
WhiteNight's Avatar
WhiteNight
WhiteNight is offline
It's the slip yoke.I just got mine done saturday.Cured the problem.There is a tsb,look back in this form.
Old 05-10-2004, 01:02 PM
basstardo's Avatar
basstardo
basstardo is offline
Just to give you guys a heads up, this is a problem the Super Duties have been having for a while as well. If there isn't a TSB, just drop the shaft and grease the slip yoke. Takes about 20 minutes. Just be sure to set your parking brake and chock the tires. A few guys have almost been run over by their own trucks!
Terry
Old 06-23-2004, 10:36 PM
reg123's Avatar
reg123
reg123 is offline
What Type Of Grease For This Slip Yoke?..my Truck Does This Clunk Also Now..1000 Miles On It...
Old 06-24-2004, 08:25 AM
basstardo's Avatar
basstardo
Use regular grease you would use to pack bearings with. I just bought a can of high temp grease that was made for Ford vehicles, Valvoline brand I think. I coated the splines on the driveshaft real good and put everything back together and zero clunk at this point.
Terry
Old 06-24-2004, 04:45 PM
WhiteNight's Avatar
WhiteNight
I thought ford recommended a silicon grease, and yes there is a tsb.Mine has been done, problem solved.
Old 06-24-2004, 04:52 PM
scottb1014's Avatar
scottb1014
scottb1014 is offline
God this ****es me off. I am taking my truck in for the 3rd time this Monday over this issue. They couldnt find the problem,
OMG
Old 06-25-2004, 10:03 AM
rjs1521's Avatar
rjs1521
rjs1521 is offline
i'm getting the same rumble on take off when the truck has been sitting overnite. I have felt the clunk on occasion but credited it to our finely manicured roadways here in New Jersey. I'll besetting up an appointment next week for replacement of the clutch packs and a lil lube on the slip yoke.
Old 07-07-2004, 07:53 PM
mwh's Avatar
mwh
mwh is offline
about how often does a slip-yoke need to be greased on these '04 f-150's.(this is assuming it was done properly at the factory). i have never been bothered by anything like this on any of my previously owned vehicles (they weren't fords). why now?
Old 09-07-2004, 01:06 PM
garymake's Avatar
garymake
garymake is offline
Between this topic and one other in the '04 - '05 F150 forum, three types of grease have been specified for the drive shaft splines - high temp wheel bearing grease, silicone grease and teflon grease....
anyone know for a fact which is the correct grease to use?
My unofficial poll of the various entries in multiple topics dealing with rear end clunk seems to find that the majority of folks that have taken it to the dealership to get the splines greased are saying that the dealership used teflon grease.
Please let us know the source of your information if you post an answer so that we can separate fact from opinion...
Old 09-07-2004, 04:20 PM
Fcal's Avatar
Fcal
Fcal is offline
Talking
Just got mine back from the dealer last Friday. they greased the slip yoke and replaced the clutch pack in the LS differential. There are 2 TSB's for this problem. The Shudder after sitting overnight is the Clutch Pack and the clunk on acceleration is the slip yoke. Dealer did both with no questions on the first visit.
I was stunned.
The TEFLON Grease is the one they used on my truck. Straight from the service manager's mouth. Also on my repair receipt.
Old 09-07-2004, 10:48 PM
jrog23's Avatar
jrog23
jrog23 is offline
did this noise start happening from the very beginning of you owning your trucks?
Quick Reply: Slight clunk/jerk at takeoff
