TTB Axle shafts and U-Joints
I've already got the Hayens manuel but I didn't see anything that told me how to do the U-Joints... do they have snap rings on the outer side, or do i just beat one side out and then the other? I know how to get the axle shafts out but its just getting the U-Joints out that I am concerned with.
They can be stubborn to remove. The locking clips are internal and are hard to see if you have tons of rust like I did. Remove the clips and place the yoke ears between the open jaws in the vice and hammer down on the other yoke to pound the caps out one at a time. This method has worked well for me to remove ujoints. I did however run into a major rust problem in which I could not remove the caps once pounded out, (totally rusted to bearings and spider journal) had to grind flat spots on cap place in vice and use a 3 foot pipe on another spider journal and work PB Blaster in while rotating to remove.
Alternate method is to use a 3 in 1 ball joint ujoint tool to press out. You can rent for free at Autozone.
Rust never sleeps. You can do it, Good Luck
Also, Think about upgrading the U-joints to something like CTM at http://ctmracing.com/ or ones from OX. I don't have web site for them but here is a picture
Originally Posted by rlh
Stock TTB in a bronco is Dana 44. The best option for the Dana 44 stock type carriers is the spicer 5-760x ujoints which are a direct replacement for the 5-297
joints that came in it. They are $20 each vs.$185 each for the CTM. Multiply that times 3 and that is $60 vs almost $600.
Originally Posted by tite4x4
And then you would multiply that $60 by how many times you break those week links, which will ultimately end up to about the same as the one time price of the $600 set of good U-Joints. I have thought about going the cheap route and buy those $20 parts, BUT My Atlas II transfer case and KluneV under drive unit will eat them alive.
Tite4x4, what tranny are you using with the Klune V? How did the drive shaft length workout?
That's why I'm waiting until ARB comes out with thier 35 Spline Air Locker, and then have the custom axles made to fit. Then I'll work on the hubs and knuckles, when I cross that road. Bassically I'm trying to prevent future breakage. But nothing is full proof. Granted even the strongest of parts can break.
I have the E4OD tranny, that I'm about ready to rebuild with all the updated heavy duty parts installed. The previous shops that had rebuilt it for me in the past did not take this into consideration. They could be built to handle all the torque & HP that I have.
The new custom drive shafts worked out perfect after the installation of Atlas II/KluneV. The front was about 3" longer and the rear was about 3" shorter than the stock shafts. I had upgraded the U-joints to 1350 and the rear shaft is of the 1 ton veriaty, and the front has thicker wall material. Guy at Tom woods had assured me that this would be just fine for what I have.
BTW rlh - What don't those people like about the OX U-Joints?
NotSoSporty98
11-27-2015 03:04 PM
BenS77
01-26-2014 11:17 AM
robinsonpowerstroke
08-03-2010 07:33 PM
fordguy351w
12-28-2003 04:54 PM
