Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2004, 09:40 AM
Rondigsit is starting off with a positive reputation.
Question 99 Ranger New DPFE=Rough idle
I had a diagnostic done on my Ranger because of it sputtering under acceleration, the shop told me it needed new plugs - Done, new wires - Done, new DPFE sensor - Done, also before any of this I put on a new fuel filter and I checked the MAF sensor, looks good. Well now I 've got good acceleration but an extremely rough idle. I'm not sure of my next step, I looked for vacuume leaks didn't find any, should i replace the EGR?
Any help would greatly be appreciated.
  #2 (permalink)
Old 04-14-2004, 11:23 AM
Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE.
Before replacing the EGR valve, try resetting your PCM. You can do this by disconnecting your negative battery terminal, turning on your headlight switch, and wait about 10 minutes, before connecting back the battery terminal.
Good luck!!!
  #3 (permalink)
Old 04-14-2004, 12:11 PM
Rockledge's Avatar
Rockledge has a great reputation on FTE. Rockledge has a great reputation on FTE. Rockledge has a great reputation on FTE. Rockledge has a great reputation on FTE. Rockledge has a great reputation on FTE.
Welcome to FTE!
Are you currently getting any "check engine" lights? Was the idle OK before the new parts were installed?
You said you looked for hoses or electrical connectors that might have gotten knocked off during the recent tune-up. That is first thing to do.
Also, keep in mind that it usually takes some driving time for the PCM to re-learn the several different operating strategies it uses, including idle strategy, after it has been reset.
You might consider the IAC valve as a possible cause of the bad idle ...first basic test is to unplug the electrical connnector and see if the engine stalls or nearly stalls.
Keep is posted.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #4 (permalink)
Old 04-14-2004, 12:40 PM
I did undo the neg cable but didn't turn the headlights on, and I did get a new check engine light after I cleared the computer, as far as idle, if had a skip in it, same as when it was under acceleration before but not a rough idle. I'll check the IAC, I believe I tried that before repairs and it died, I assume if it stalls or dies when unplugged it is working properly?
And thanks for the welcome and information!
  #5 (permalink)
Old 04-14-2004, 12:52 PM
After getting the CEL again, did you scan for codes?????
Good luck!!!
  #6 (permalink)
Old 04-14-2004, 12:55 PM
I plan to do that tonight
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
