Front Wheel bearing torque spec
Old 04-13-2004, 04:52 PM
JTD1972's Avatar
JTD1972
JTD1972 is offline
92 Ford Explorer 4wd. I read in the Haynes manual that the front wheel bearing torque is only 16 in/lbs. I torqued my front wheel bearing to 16 inch pounds and there was about an 1/8" play in the wheel (up and down). If I tighten the nut to the next notch, there is no wheel play at all. Since there is about a 1/4" between notches on the nut, moving the nut to the next notch brings the torque up to about 10 ft/lbs. Is this too tight? Will it burn out the wheel bearing?
Old 04-13-2004, 05:02 PM
jclj2003's Avatar
jclj2003
jclj2003 is offline
what i did is i tighted the nut down by hand when their was no play and i put the pin in and had no problems if u thighten 2 much it will cause it to wear the bearings out
Old 04-13-2004, 07:45 PM
Opera House Works's Avatar
Opera House Works
Opera House Works is offline
Should say tighten to 35 ft-lb then back off and then tighten to 16 in-lb. Give it a good rotation before you back off. Many have not done this and found the wheel very loose the next time they checked. The extra force insures everything gets seated.
Old 02-05-2005, 02:37 PM
caryheath's Avatar
caryheath
caryheath is offline
Talking Here's a hack
I made a shim out of a soup can lid. I didn't have any shim stock. It moved the nut out just a little. That was enough to put just a small amount of torque on the nut and have the slot line up.
This is a non-rotating part so I split the shim to make cutting it out easier.
Old 02-05-2005, 02:55 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Caryheath...
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Great first post...
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
flydubber
15
02-02-2023 04:49 AM
99ExpyProblems
10-04-2013 02:55 PM
HOWNDOG
07-17-2011 09:58 PM
zzrich
04-11-2010 03:27 PM
FlyinFord
1999 to 2016 Super Duty
10-23-2009 08:23 PM
Quick Reply: Front Wheel bearing torque spec
