How long is to long to leave block heater plugged in,
Some folks buy a timer to plug the block heater into. This way if you regularly leave home around 7:00 AM you can set the timer for the block heater to come on around 4:00 AM to save on the ole electric bill.
I have a 2002 F350 and just started plugging it in using a timer (about 3 hours before starting). I thought I had read that if I leave my heater on, the truck would be warm in the morning. This does not seem to be the case. Does anyone know if the block heater heats the coolant or oil?
It heats up the coolant in the engine block. It will not generate enough heat so your engine will be warm when you crank it. The block heaters purpose is to aid starting in cold weather.
I have good luck plugging mine in for about 2 hours unless it's under 10 degrees, then I give it about 3 hours. It also sits in a garage so there is no breeze to suck the heat back out of it. Has anyone tried a blanket over the hood when parked outsite?
