Best 302 Cam
Old 04-08-2004, 06:34 PM
AceTrucking's Avatar
AceTrucking
AceTrucking is offline
Best 302 Cam
Looking for opinions on 302/351 camshafts....here's what I have so far
c90e 35w heads, 2.02 intake, 1.60 exhaust port/polish/valve job
Block .30 over with ford racing flattop pistons...
Bulit c6 and 3.89 rear ratio
My question is this: What is the best cam for my setup? I'm open to both hydraulic and roller opinions, to see which will create the most power for me.
Old 04-08-2004, 06:57 PM
buzziscrazy2's Avatar
buzziscrazy2
buzziscrazy2 is offline
i LOVE MY "e" cam.........mild motor, Dyno'd 393 hp
Sorry i'm a pic freak.........Buzz
Old 04-08-2004, 11:03 PM
umdstang's Avatar
umdstang
umdstang is offline
comp cams recomended a 270 magnum cam with flat tappet lifters for my 302 with about the same set up, you might go to the 268 if you want more low end torque, or the 280 if you want more high end power.
What kind of vehicle are you putting it in?
Also check out the thread "best cam for 302" in both this forum and the general engine building forum.
Hope that helps
Brian
Old 04-09-2004, 06:35 PM
Jimbo302's Avatar
Jimbo302
Jimbo302 is offline
What's the combo there, flywheel numbers?
Steven Walker
15
10-19-2016 08:47 AM
easyridin
08-27-2015 06:06 AM
mroseboom10
05-21-2015 02:05 AM
aclifton14
03-10-2015 07:50 PM
arnolan
04-15-2003 08:13 PM
Quick Reply: Best 302 Cam
