Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-08-2004, 02:20 PM
Fordication's Avatar
Fordication is new and has a neutral reputation at this point.
Y-block transmisions
What modern transmissions will fit a Y-block motor in both automatic and manual. Without having to purchase an adapter that cost over $300. Ed
__________________
Ed Walden
1954 Ford F-100 Blah
1972 Ford Mustang Grande Coupe
2006 F-150 Supercrew-Lariat-Oxford White
  #2 (permalink)
Old 04-08-2004, 06:43 PM
312 312 is offline
312 is starting off with a positive reputation.
the fmx will fit with a little work.it was used from 67 to the early eighties.any stnd,will fit up till the t5.all will require a little work.
  #3 (permalink)
Old 04-09-2004, 02:55 AM
kens64 is starting off with a positive reputation.
What type of work is involved? Anything have to be fabricated?
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
JOIN THE NEW MEXICO CHAPTER HERE
  #4 (permalink)
Old 04-09-2004, 07:45 AM
312 312 is offline
with stnd,it,s mostly driveshafts.with the fmx it,s to bad you couldn,t get hold of a copy of sept,99 street rodder .it has the whole thing in detale.
  #5 (permalink)
Old 04-09-2004, 11:20 PM
pcmenten is starting off with a positive reputation.
I believe that there are three, maybe four, bellhousings for the Y-block; two are standard transmission bells, and one is for the FordoMatic (FM). One of the standard transmission bells might fit up to a toploader or a T-10. Your transmission choices are T-85 and T-86 with and without overdrive, T-98 (granny low), and the FM. The FM can be adapted to the FMX and that's a pretty reasonable choice. That might be the most modern of transmissions.
Do a google search and you'll find articles about what it takes to adapt the FMX to the FM bellhousing.
__________________
Best regards,
Paul Menten
  #6 (permalink)
Old 04-10-2004, 01:31 AM
I have been looking but I just cannot part with $700 to go more modern. Are any of those manuals 4 or 5 speed manuals. I have a 3 sp OD manual now and want more of a modern feel. Ed
__________________
Ed Walden
  #7 (permalink)
Old 04-11-2004, 01:52 AM
Ed, I think the bellhousing that fits to the T-18 will take either a toploader or a T-10. If it takes the toploader, then it will take the RUG version of the toploader; a four-speed overdrive transmission.
Hold on, I'll go look at some of my stuff to see what fits.
Ok, here's a news flash. My RUG case has a pair of bolt holes at all four corners. One set of holes lines up with the holes on a 3 speed bellhousing!!!! I'm shocked!
Just to be clear; it looks very much like you can use a 4 sp overdrive RUG toploader transmission as a replacement for the stock 3 speed. Pictures available upon request.
Tomorrow, I'll dig out a Chevy T-10 and see if it fits up to the T-18 bellhousing.
__________________
Best regards,
Paul Menten
  #8 (permalink)
Old 04-11-2004, 02:51 AM
Ok what the heck is a RUG and please tell me more. 4 spd overdrive? Is that 3 gears then an overdrive or 4 then and overdrive. What is a t-18. Ah shoot more searches coming up. Ed
__________________
Ed Walden
  #9 (permalink)
Old 04-11-2004, 11:06 PM
Ed,
I don't remember what in particular the letters RUG stand for, but those letters are used to identify a version of the toploader transmission that is an overdrive trans; the high gear is overdriven. Third gear is the direct drive (1:1), and fourth is overdrive.
I have a NOS RUG case and it has two bolt patterns drilled, and one of the bolt patterns fits the T-85 3sp transmission bolt pattern perfectly. I can post pictures on my forum if that would clarify things.
Right now I wish I had a truck V8/3sp bellhousing. I've got three 4sp, one Fordo, and a FE/4sp truck bellhousings (plus the 223/3sp that's in the truck right now).
Edit; I forgot to describe the T-18; it's a 4sp with a granny (spur cut) first gear. Shifter on the top, a common option for light duty trucks.
__________________
Best regards,
Paul Menten
  #10 (permalink)
Old 04-12-2004, 12:42 PM
Ok so this T18 or T19 should bolt right in then? Now that is interesting. I have seen pictures of a T5 bolting in after some mods but according to many the T5 is not that great a transmission.
__________________
Ed Walden
  #11 (permalink)
Old 04-12-2004, 06:20 PM
Ed.
Yes, the T-18 four speed is a factory original option on F-100, F-250, F-350 and standard equipment on F-500, F600, and F-700. Must be a strong bugger. I'll repeat myself so that we're clear, the T-18 has the spur-cut granny-low (6.40:1) first gear and a direct drive fourth gear. I've been offered T-18's for cheap but I already have one and I don't think I'll ever use it.
I do have the bellhousing(s) for it.
The usual T-5 is rated for 265lb/ft of torque. If driven hard, the stock 302HO will break it. There are versions capable of 300lb/ft; they have a different gear set in them.
-Paul
ps. I might have a line on an entire RUG 4sp.
__________________
Best regards,
Paul Menten
  #12 (permalink)
Old 04-12-2004, 09:20 PM
Ok I am confused. What is the RUG 4 number. I thought it was the T18. Is it the T19 or another transmission. Will the stick be in the correct place in front of the seat or is it like some of the others the stick is under the seat. Ed. Let me know about that Rug 4sp please. Ed
__________________
Ed Walden
  #13 (permalink)
Old 04-12-2004, 09:37 PM
Yup, I've confused you. My apologies.
The T-18 is a factory original four speed. The RUG is not a T-18, it is a very different transmission from another era, the 80's.
The T-18 is a standard truck transmission. Strong as heck, spur cut first gear, syncro in 2nd through 4th gear. Fourth gear is direct drive; 1:1. Normally people start out in second gear unless they've got a load or they're pulling a trailer.
The RUG is not the same as a T-18. The RUG was installed in some Ford cars in the late 70's and early 80's. It is a four speed with fourth gear overdriven. Third gear is direct drive 1:1. It has a bolt pattern that will fit up to the bellhousing for the 3 speed manual transmission found in many 50's F-100s. The shifter is slightly back from where the T-18 shifter would be. A person would want a shift lever with an offset to help with seat clearance.
__________________
Best regards,
Paul Menten
  #14 (permalink)
Old 04-12-2004, 10:33 PM
Ok I am game. Where do I start looking and how much should it cost. ed
__________________
Ed Walden
  #15 (permalink)
Old 04-12-2004, 10:36 PM
Dino@his Dad's is starting off with a positive reputation.
5spd Y block
Fordifacation, how about a Clark 5spd ? There were 5spd Clarks offered in some of the bigger ford trucks. I believe they were the 260 series. They feature a low first gear, 6 1/2~7 to 1, and direct drive in 5th. 1st is made with straight cut gears, like alot of truck trannies. DF, @ his Dad's house
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
