Y-block transmisions
Old 07-26-2004, 10:30 PM
Fordication's Avatar
Fordication
Fordication is offline
I am also looking for reasonable gas mileage. An auto that only has 1 and D is not going to get it. I also found out that the T5 may not be the way to go for a stick to wind up where it should. Ed
  #47
Old 07-27-2004, 03:08 AM
Janet40's Avatar
Janet40
Janet40 is offline
I agree!!! Gasoline is becoming a major investment anymore!!! see what many do not realize is 50% of the time, you are getting gasahole at these pumps anyway, which burns even faster)..As tall a rear end gear one can find doesn't hurt. The FMX with the cast iron case i rememberdealing with, was a guy that had an old beat up workk truck with the unmodified cleveland V8,351 he did rather good on fuel luckily..I never checked the times the driveshaft turned per the rear wheel on tis e though, so i don't kow what ratio he back there, but he got decent fuel mileage.i seem to have the best mileage with Shell fuel for some reason.But with the 55 Fairlane, that 3 on the tree manual is a fun car to drive, but in my 63 ford unibody. i', wamted to go with automic on that one, sees by camparing,we seenm t get better mileage here for some some reason, it may be because we hae the humid thicker air down here,Seems like i keep getting white fast burning gasahol at these racetrack fuel stations,.Janet
  #48
Old 12-08-2013, 01:13 AM
Captd's Avatar
Captd
Captd is offline
Hey I'm new to this forum and new to my 56
Does any one have any pictures if the shift linkage on the 56 f100 for the 4 spd someone looks like they made mine
Thanks in advance
  #49
Old 12-09-2013, 12:05 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,649 Likes on 1,345 Posts
Welcome to FTE.
You can start your own thread for questions like this, no problem.
Your '56 F100 would have had a Borg Warner T98 for a four speed as OEM.
No external linkage, as you can see:
The Borg-Warner T18 & T19 Transmissions - Novak Conversions
Your four speed, does it look like one of these?
Remanufactured Toploaders
or:
http://www.socalsacc.com/images/Tech...%20Picture.jpg
Neither the toploader Ford or BW T10 were ever offered in a stock pickup. The closest would have been the toploader derived 4 speed OD trans from the mid '70s to mid '80s. So, if you have a '60s car four speed, whoever installed it may well have made their own linkage.
You may be able to buy a Hurst shifter that would work, but we need to ID your trans first.
Badass56
04-17-2018 10:19 AM
Cobwebman
06-12-2016 12:36 AM
fastphil
10-01-2011 01:22 PM
yield2s
13
03-12-2008 12:44 PM
Fordication
07-29-2004 08:55 PM
Quick Reply: Y-block transmisions
