Port Matching Pics
port matching
Winchester, what are you trying to match the heads to ? Most guys, when porting the floor of the intakes ( or the exhausts ) remove as little material as possible, just cutting away enough to make sure the flow is smooth. Lots of my intake ports on my C8s and D2TEs have no material ground out of the floors, I used a sanding roll to polish it smooth and left it at that. What your doing with the mill looks great up on the top of the ports. Do some blending with a hand grinder and they'll be wonderfull. But the floors are low enough to have me concerned. What is your goal here ? DF
Sorry guys I guess I should have explained myself a little more. That head I did was a junk head and I was just playing to see if the mill would do the trick. I by no means intend to take off that much material. I did cut throught those ports to see how close the water jacket was. Still had a ways to go. FYI I remove about 1/2" from the slope on that test.....
I'll post my actual pics from my real heads once I get them done...
kilich
11-27-2011 08:54 PM
cjben
09-09-2008 11:47 PM
